What should I look at while I am in there?
I already replace all of the front end bushes on my 2004 XK8 as well as the air struts. I still have a clunk in the front passenger side over bumps so now plan to replace the two drop links as well as the sway bar bushings. While I am under there I will change the engine oil and filter. Anything else I should look at while I am in there? For the record, I also replaced and tightened the transmission cable bracket, serviced the transmission with new sump and seals and also replaced the windshield wash bottle. At this rate I will run out of things to do on the old girl.
Steve
Steve
auburn2
Dec 12, 2015 08:33 AM
sunchip
Oct 27, 2013 04:25 PM
RRT
Feb 10, 2013 09:26 AM
