Where is connected "end" hose from AJ87977 transducer ?
Old Aug 7, 2016 | 02:06 AM
roman_mg's Avatar
Default Where is connected "end" hose from AJ87977 transducer ?
Daimler X350 4.2 SC MY 2006.
I have problem with connecting vacuum hose "end" from transducer on the rail. I make restoration of engine and I lost photos
Does anyone know where the "end" is involved ? See pic, please.
Photos will be best, but explanation is also very good
Thanks for the help, Roman.
Attached Thumbnails Where is connected "end" hose from AJ87977 transducer ?-pic3.jpg
Old Aug 7, 2016 | 04:58 AM
woox4's Avatar
To the little pipe sticking out next to the supercharger bleed plug. It is the black & white tube in this photo.
Old Aug 7, 2016 | 10:11 PM
jackra_1's Avatar
On my 2005 XJR that vacuum hose connects on the back drivers side of the "spreader" .
By spreader I mean the casting that the SC pushes air up through to both charge coolers.
The connection on my 2005 XJR is almost dead center of the pic.
I have no such connection as shown in Woox's picture. So maybe a change in the 2006 model year.
Attached Thumbnails Where is connected "end" hose from AJ87977 transducer ?-2016-08-07-22.03.38.jpg
Old Aug 9, 2016 | 01:19 PM
roman_mg's Avatar
Thanks for the answers and help.
Picture from JEPC is not (maybe) up to date, because my JAG MY 2006 have connected "my missing" hose end (hose have T-piece and 3 ends) to the vacuum reservoir under RH wing.
Old Aug 9, 2016 | 01:55 PM
jackra_1's Avatar
Item #4 in your diagram sits on the back of the left hand side fuel rail and looks exactly like my car.
Item # 7 on my car is a white T piece with the right angle connection blanked off and going nowhere.
The longer rubber connection leading away from the T piece connects on the back of the "spreader" I mentioned.
That connection at the left hand side rear of the spreader is easy to see with the cover off.
If you do not have that connection then you probably have what chris is showing in his picture.
Does your supercharger coolant top up plug look like this? The picture is showing the top up "hole" without the plug in it.
This top up cast is a dead end at the side nearest the back of the engine and has no other connection other than the rubber pipe at the front.
Attached Thumbnails Where is connected "end" hose from AJ87977 transducer ?-2016-07-29-07.58.54.jpg
Old Aug 11, 2016 | 08:23 AM
roman_mg's Avatar
Default New beginning :)
Sorry I must make new beginnig, I think, that pics are better.
1. Long vacuum pipe
Left hand is clear, but where are going two ends in the right hand ?
"Left hand" beginning there :
Code of the pipe:
2. Where is connected the second pipe from TB ?
3. And what is connected here ? (left and right index finger)
4. Which pipe is conneceted to reservoir ?
Top and LS of the engine:
I'll never lose any photos
Thanks Roman.
Old Aug 11, 2016 | 08:55 AM
jackra_1's Avatar
Your hose connections are quite different from mine so cannot help.
Actually just had another look at your pics. In picture #3 your right hand is pointing to the same connection I have at the back of what I called the "spreader".
richzak
Jul 2, 2016 10:29 AM
o1xjr
Feb 17, 2016 06:10 AM
XJsc-guy
Sep 2, 2015 11:43 AM
rothwell
Dec 17, 2009 08:09 AM
