whole control arm or just bushing?
Old Nov 25, 2016 | 04:46 PM
thomash85715's Avatar
Default whole control arm or just bushing?
Hi 04 xj8 has had clunk noise when hitting bumps since I got it last year. Local brake max showed me the play in the lower control arm big bush where it mates to the frame. They say the bush cannot be replaced, must buy whole arm at $600+each. Yet many parts sources including dealers show the bush as a $60 item. Can it be replaced without destroying the control arm? Some people on here state bush only can be replaced while keeping old arm. What is definitive final answer on this please? Thank you.
PS: relevant part number is c2c4437 I think.
Old Nov 25, 2016 | 05:12 PM
viper1996's Avatar
The Lincoln control arms fit and are waaaay cheaper...Do a search use Lincoln in search box...
Old Nov 25, 2016 | 05:13 PM
Sean W's Avatar
Your shop seems to defy logic if you're able to locate the bushing online. Yes you can press out the old bushing and replace. No need to buy the control arm. A machine shop can press it if you don't have the tools.
Old Nov 26, 2016 | 02:53 AM
Fraser Mitchell's Avatar
It's important not to damage the arm whilst swapping bushes. These are aluminium forgings and it is possible to create a crack site.
Old Nov 26, 2016 | 03:54 PM
meirion1's Avatar
Some people have placed the new bush in the freezer and the
arm in hot water prior to fitting.
Can't say anymore since I have not had to do it myself.
Old Nov 26, 2016 | 04:56 PM
Yes, a useful tip and one I also heard about.The aluminium expands twice as much under heat as steel so the gap for the bush to fit into will enlarge and ease the process. It also works on the removal of the old bush too.
Old Nov 27, 2016 | 02:54 AM
JagsteRJX's Avatar
Just had the two large bushes in the curved lower control arms replaced. Shop didn't have any issues pressing them in.
Old Nov 27, 2016 | 05:49 AM
Partick the Cat's Avatar
Ditto, by an indie down in darkest Somerset. They said the small bush lasts much longer.
