Windshield washer inop
Old Sep 16, 2014 | 06:33 PM
Rufus T. Firefly's Avatar
Default Windshield washer inop
Windshield washer seems to be totally inop, but i can see the headlights are getting spritzed intermittently. Any ideas on how I should conduct the troubleshoot procedure? Thanks
Old Sep 16, 2014 | 06:48 PM
34by151's Avatar
Check he fuse and if thats ok check you are getting power at the pump when you turn on the washers and you dont have blocked jets
34by151
Old Sep 16, 2014 | 06:54 PM
Okay, I just discovered that there is a leak or disconnected hose. The pump is running, but when it does, it's just pissing the washer fluid out toward the bottom to the ground.
Am I correct that to get access to the fluid reservoir is through the LF wheel well, and I would need to remove the wheel well liner?
philwarner
Jan 31, 2016 09:36 AM
King Charles
Oct 16, 2015 01:25 AM
