Windshield Wipers Park Incorrectly
Old May 18, 2018 | 05:54 AM
sjdunk's Avatar
Default Windshield Wipers Park Incorrectly
I have a '08 XJ Vanden Plas and on the auto setting, the wipers park in the middle of the windshield. If it rains hard enough, they reactivate for a couple rotations and freeze again. The same happens on the intermittent setting. On the continuous setting (both mid and fastest speed), this isn't an issue but is quite annoying when there is a light drizzle as they also stop when activated manually. Any suggestions as to how to fix this issue?
Old May 18, 2018 | 06:05 AM
Welcome to the forum sjdunk,
I've moved your question from Jaguar Forums Feedback & Suggestion Centre to X350 forum. Members here with the same model will be able to help.
Old May 20, 2018 | 02:36 AM
genec's Avatar
Electrical issues can have several different causes and therefor several different fixes. When my wipers were acting strangely, tightening the main chassis grounds behind the headlights did the trick (Moisture in the air exasperates the problem). But remember, the bolts and nuts are aluminum (fragile) so tighten them like spark plugs, not head bolts. Also, look for corrosion around the bolts/nuts. Mine were clean, just needed to snugged down.
I replaced the battery and TPS first but neither of those things helped.
Good luck! Gene
Old May 20, 2018 | 06:37 AM
markwortham's Avatar
This also happened to my 07 XJL early on. After several trips to the dealer, they replaced the wiper motor and it has not occurred since.
Old May 20, 2018 | 09:22 PM
meirion1's Avatar
+1 0n headlight earths
Old May 25, 2018 | 10:23 AM
humbug2's Avatar
I also have the WSW stopping problem. But I can not find anything like a ground point on my 2008 XJR.
Could someone give me a pointer? Do I need to remove the shield above the headlights?
Old May 25, 2018 | 05:01 PM
meirion1's Avatar
post no 3
Just to the right of centre in photo.
https://www.jaguarforums.com/forum/x...dlamps-136236/
tberg
Oct 3, 2014 05:55 PM
Paul Mason
Mar 6, 2012 10:44 PM
diverguy
Feb 10, 2011 12:02 PM
jensenman4
Sep 9, 2010 06:52 AM
