X350 interior door handle.
Old Jul 25, 2025 | 11:09 AM
pj3426's Avatar
Default X350 interior door handle.
My X350 drivers interior door handle clicked when I pulled it open the other day, now it doesn;t completely return,
it just just flops about for the final 10-15 degrees. Any ideas, I have just purchased an interior trim removal kit.
Old Jul 25, 2025 | 02:47 PM
Thomas-S.'s Avatar
Might be that the spring that has the task to make the handle return to the original position has broken. I assume that you will need a new handle.
BTW, to remove the door trim you do not need the interior trim removal kit, normal tools are sufficient.
Best regards,
Thomas
Old Jul 25, 2025 | 05:56 PM
meirion1's Avatar
+1 Broken spring
Old Jul 26, 2025 | 03:35 PM
Pete M's Avatar
Best regards,
Thomas
Hi pj3426,
My car had exactly the same problem when I got it. The spring is a torsion one around the interior handle pivot. I found a similar sized spring (about 10 mm diameter) in my scrap bin. I put the two pieces of broken spring together and worked out the angles of the ends. I used a pair of strong pliers to shape my scrap spring into a roughly similar shape. It has lasted six years so far. I don't think you can buy the spring separately. I also made one for a local forum member who had the same problem.
Pete M
Jaguar XF Yorkshire
Jan 24, 2024 10:15 AM
scjordan1969
Jan 10, 2022 04:31 AM
randyb
Aug 29, 2013 11:18 AM
nickthap
Aug 21, 2011 04:52 PM
pezzonovante88
Jul 11, 2011 08:51 PM
