X350 Lock Doors issue : passengers can't be open when the locks come from driver door
Hi to all !
I have an issue with an XJR of 2004.
In my X358 , when you lock the doors with the driver door or with the central button of dashboard you can unlock all doors from inside , just to pull the trigger of each door.
But in the XJR if you lock with driver door or the button , the other doors are totally locked.
But if you lock with the front Passenger door , you can open all the doors.
I try with SDD to take a look for the Dealers options but I see nothing to change.
After some try , now I can unlock the left rear Passenger door like in my X358.
I have no DTC for central locking but I have two DTC for the fuel sender unit with the REM module.
So have I a problem with REM ? Door lock ? Files configuration ?
Many thanks by advance and sorry for my not really good english.
Regards,
Tom
Regards,
Tom
With this car , I only have one key.
The double lock is normally desactivated.
I observed this fact too this week-end :
When I closed all doors by the front passender lock , if I open by the central button or driver door , passenger lock stay locked until I pull out the trigger of passenger door.
So , maybe it's the passenger who have a failure with electronic control.
Thnaks,
Tom.
max224
Jan 17, 2022 10:43 AM
Danial Dano Rustan
Feb 23, 2012 01:44 AM
