Xenon light out!
Old Feb 15, 2010 | 01:14 PM
ron44094's Avatar
Default Xenon light out!
The left side xenon light on my 2005 XJ8 is out. I swapped bulbs and it is not the bulb as neither bulb works in the left position. I also checked the fuse box and eache light is on a seperate fuse - no problem there either. It takes the D1s bulb - can I assume that the ballast is out - or is there possible a less expense cause?
Old May 9, 2010 | 07:42 PM
TFB3's Avatar
Cool Xenon light out
I am having the same issue with my factory intaalled x-type.
new bulb lasted 3 min and then went out..
Igniter, ballast ?
I'm at a loss.
Any resolution for you?
TB
Old May 10, 2010 | 08:41 AM
Brutal's Avatar
useally the ballast, not avail seperatly. But I have 1 for $150 shipped... unless youre not in the Upper 48 states you dont list location
Old May 18, 2010 | 04:23 AM
given's Avatar
Hie, I've the same problem on my XK8 2003.
One lamp is out (D1S), but swapping it works, I've still made no other tests, did anyone solved ? I'ld like to try an universal ebay's ballast...
Old May 18, 2010 | 06:41 AM
steve11's Avatar
ud
Given,
If I understand correctly, another bulb works, but the original bulb does not work. If that is the case, it sounds like you have a bad HID, not the ballast.
If so, I found a good aftermarket supplier of D1S bulbs on Ebay. At least for the price ($60/pair) they're far less expensive than OEM D1Ss. I have them in my X350 for a couple of month now and I am happy with their performance. I tried the 8000K which are a little ice blue, but nice and bright. The Ebay company is Formula-J87 (no affiliation).
Try searching for them on Ebay and hopefully you can purchase them in Italy if you discover, in fact, that the bulb is expired.
Old May 19, 2010 | 03:03 AM
given's Avatar
Thanks Stevetech
but I explained wrong.
If I use the left lamp on the left side, that does NOT wors, BUT if I use the left lamp on the right side, that WORKS!
Old May 19, 2010 | 06:33 AM
steve11's Avatar
ud
OK, Yes, with that clarification it does sound like you too have a defective ballast.
Jpav27
Jul 31, 2022 06:43 AM
afterburner1
Dec 16, 2015 12:12 AM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
