Xj6 oil drip
Old Nov 12, 2017 | 04:25 AM
davidcumbria's Avatar
Default Xj6 oil drip
Dripping engine oil. Suspect pan / sump gasket. Anyone done this job on an Xj ?there is big issue with hard to access bolt discussed on x type but can't find anything in xj section
Old Nov 12, 2017 | 12:40 PM
Fraser Mitchell's Avatar
If your car is the X350 with the V6 3 litre petrol, then it is likely to be the sump gasket. I had to replace mine on my previous X350. The cost is not low due to the amount of dismantling needed to get the sump off.
