XJ8 Documented Air Filter Change.
Old Oct 16, 2013 | 02:10 PM
trosty's Avatar
Post XJ8 Documented Air Filter Change.
I have replaced the air filter and thought I would document what I found to aid other people.
I ordered a WIX 42261 Air filter that arrived today and set to swapping them straight away. The sequence of events is as follows:
1. Raising the bonnet (Hood) I located the Air filter box to the front right of the vehicle. It is held in place with two plastic toggles and is very easy to unhook. I raised the cover without the need to remove the connecting pipe. Your veh may differ slightly.
2. I removed the old air filter. This was disgustingly filthy, too small in depth, length and width and carried out no service to air filtering to the engine whatsoever.
3. I compared the old and the new air filters.
4. I cleaned the air box and inserted the new air filter. It fits perfectly in length, depth and width.
5. I checked and cleaned the air flow sensor.
6. I put it all back together making sure the air filter was correctly seated. When attaching the cover, make sure the left locating lugs are correctly seated and then push the cover down to lock home the two right lugs. Job Done.
Attached Thumbnails XJ8 Documented Air Filter Change.-jagsunroof1a.jpg   XJ8 Documented Air Filter Change.-jagsunroof3.jpg   XJ8 Documented Air Filter Change.-jagsunroof1.jpg   XJ8 Documented Air Filter Change.-jagsunroof2.jpg   XJ8 Documented Air Filter Change.-jagsunroof4.jpg
XJ8 Documented Air Filter Change.-jagsunroof5.jpg   XJ8 Documented Air Filter Change.-jagsunroof6.jpg   XJ8 Documented Air Filter Change.-jagsunroof7.jpg
Old Oct 16, 2013 | 02:45 PM
trosty, good work but no pics!
Old Oct 16, 2013 | 04:01 PM
trosty's Avatar
Thumbs up
Sorted now
Old Oct 17, 2013 | 08:16 AM
mhamilton's Avatar
The only thing I would add, if you remove the 10mm screw from the end of the air box it lifts right out (watch for sensor connection wires). Makes it a lot easier to get the tabs engaged when installing the lid.
Old Oct 17, 2013 | 09:06 AM
paydase's Avatar
Was the original air filter an OEM one? Cannot be!
Old Oct 17, 2013 | 10:40 AM
trosty's Avatar
No the previous owner had fitted it with a cheap Chinese imitation that was completely off spec. It really did look like it had not been changed for a long time.
Old Oct 17, 2013 | 04:46 PM
XJRTrooper's Avatar
Great write-up! I just removed my K & N filter, cleaned and replaced it. I'm glad I did because the entire air box was filled with dog food! The former owner must have owned a dog and had mice! I did the WOT flap removal mod while I was at it. The car runs great. I can really hear the SC whine now!
Jandreu
Jun 30, 2022 03:10 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
1964Daimler
Sep 9, 2015 11:28 AM
1100me
Sep 7, 2015 06:26 AM
Wes Steenrod
Sep 6, 2015 06:52 PM
