XJ8 factory compression?
Old Nov 16, 2014 | 02:16 PM
Isoruku's Avatar
Default XJ8 factory compression?
Hi everyone. This is my first post. Tomorrow I may purchase a 2004 XJ8 with the 4.2 L engine. I will want to see the diagnostics at the dealership first, and especially want to know what the compression test revealed. I'm assuming that factory spec will be indicated on the printout along with the actual tested figures for each cylinder. But just in case, does anyone know what the ideal compression is on the 2004 XJ8? Many thanks.
Old Nov 16, 2014 | 03:13 PM
meirion1's Avatar
If the compression ratio is say 10:1 and atmos.pressure is 14.7psi then the cylinder
compression will be about abot 150 psi.
dsnyder586
Dec 29, 2024 07:39 PM
Jdthomas
Sep 23, 2015 06:23 AM
flyrr100
Sep 18, 2015 06:31 PM
'05 Gold XJ8L VDP
Sep 18, 2015 07:15 AM
corysansburn
Sep 10, 2015 06:15 AM
