Xj8 will not start after replace thermostat hoseing
Old Nov 8, 2014 | 12:50 PM
keneknowles's Avatar
Default Xj8 will not start after replace thermostat hoseing
Help! I have a 2004 Jaguar xj8 (x350). I had a slow coolant leak, which I traced to the thermostat hoseing. I pulled the throttle body to get to the bolts to remove thermo hoseing, all procceeded perfectly, replaced thromo hoseing, and replaced throttle body ( I did not replace the TB gasket). Checked and double checked all connections, the 2 wire green and red connection near the top of the throttle position sensor cracked, but I have the wires hand fitted red on top green on bottom and they feel tight.
Engine turns over but will not idle, could I have damaged the throttle position sensor?
The car ran perfectly with the minor coolant leak, so now I have a car with no coolant leaks and a new thermostat hosing that won't run. Any help would be appreciated.
Old Nov 11, 2014 | 08:13 PM
Figured it out! Bolts to throttle body not fully tightened, so had a huge vacumr leak, so beware and tighten all 8 bolts firmly and to torque specs for your jag.
Old Nov 12, 2014 | 04:20 PM
Fraser Mitchell's Avatar
Thanks for letting us know !
Old Nov 12, 2014 | 06:41 PM
Sean W's Avatar
Giggety
fast40driver
Apr 19, 2024 07:24 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
Xj812
Oct 26, 2015 05:04 AM
1964Daimler
Sep 2, 2015 11:41 PM
casepie
Aug 30, 2015 09:49 PM
