XJ8 window motor
Old Feb 26, 2015 | 01:56 PM
Celeta Moses's Avatar
Default XJ8 window motor
my xj8 driver window will not come down - any idea what the motor costs?
Old Feb 27, 2015 | 04:07 PM
Fraser Mitchell's Avatar
Before you start thinking about a new motor, you need to check whether it is a motor failure or a failure somewhere else. Failure of these motors is extremely rare, almost unknown in fact, with most failures caused by broken wires or switches. What you need to do is to remove the driver door panel, disconnect the feed to the window motor, and then, with an AVO meter, check to see if volts are supplied to the Up/Down connections.
However, before you do that, check the fuse. If you tried to open the window in Arctic conditions, the fuse could have blown with the window being frozen up. However, seeing you're from the "Lone Star State", it might not be a weather-related problem.
Old Mar 5, 2015 | 09:44 AM
Default xj8 window motor
I had the motor checked and was told that it was bad
I have had prices from $1000 (new) $570 to $322 (rebuilt)
The $570 was from local o'reilly parts and the $322 is from
o'reilly online. Strange.
99xk8guy
Sep 29, 2025 10:51 PM
GordoCatCar
Jan 2, 2017 01:10 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
1964Daimler
Sep 9, 2015 11:28 AM
XJsc-guy
Sep 2, 2015 11:43 AM
