XJR Supercharger Bypass Hose Mystery
Old Jan 23, 2021 | 05:05 PM
HJ808's Avatar
Default XJR Supercharger Bypass Hose Mystery
After much contortion and confusion I have hopefully traced my P0171 code to a disintegrated twin vacuum hose on the supercharger bypass actuator. The mystery for me is I am unclear what the device is on the end of one of the hoses:
I would normally associate the construction of the plastic fitting with a check valve of some sort. As far as I could tell it was just dangling amongst some other tubes and wiring and didn't seem to be attached to anything. If anyone has any insight on whether it is in fact a check valve or whether it is supposed to be attached somewhere I would appreciate it. Thanks-
Old Jan 23, 2021 | 05:53 PM
wwr's Avatar
wwr
HJ808;
I recently replaced this hose on my 07 SV8 and the end you are asking about was left unattached. I do not know the purpose of this feature but the car runs fine.
Best Regards, William
Old Jan 23, 2021 | 06:07 PM
HJ808's Avatar
Great, thanks for the info-
Old Jan 23, 2021 | 07:01 PM
Zayne Anderson's Avatar
I just replaced mine a month go on my 2008 XJ Superv8, luckily I had some videos of it before it got old and snapped.
it appears to just dangle and not connect anywhere. The code was cleared and it runs great
Old Jan 24, 2021 | 12:06 PM
HJ808's Avatar
A little more clarity, courtesy of a post from member Brutal in 2014:
"it doesnt go anywhere. thats a capped end and it is nothing more that a small vacuumreservoir"
So, just dangling seems to be correct, but, though I have no standing to second guess the Jaguar engineers, the function as a vacuum reservoir seems a little lost in the way it is configured. I would think that since the split in the hose is at the attachment to the large volume of vacuum just behind the throttle plate and the cannister is just at the end of its own little stub, the very small volume of vacuum in the plastic reservoir would have a negligible effect on the actuator. I wondered at first if mine had been installed in reverse and that the vacuum cannister should have been in series with the actuator, but my guess is that the arrangement shown in the parts diagram is correct.
Old Feb 6, 2021 | 10:02 AM
Pompey's Avatar
Banned
I had something similar on a Roush Mustang.....do the two ends clip together. I was told it was some sort of bypass that shouldn't be used......Car ran fine.
PORNO
Jun 27, 2019 07:00 AM
Windell
May 14, 2017 06:56 AM
alserry
Mar 6, 2017 12:41 PM
kmschaer
May 30, 2012 01:35 PM
