XJR timing chain slack
Old Apr 16, 2025 | 08:33 PM
04XJRdriver's Avatar
Default XJR timing chain slack
Doing new gaskets on a ‘04 XJR and decided to inspect the timing chain guides. I locked the timing with the necessary tools and marked the chains before pulling them and the guides off. Now I am struggling to get the drivers side chain back on in the same spot. There appears that there is too much slack on the non tension side. Is this a problem? Any suggestions?
Old Apr 16, 2025 | 10:44 PM
h2o2steam's Avatar
Do you just need to remove the guide(s) to create enough overall slack to successfully work that half or one link of slack around the gear so it resides on the tension side, so when you do refit the guide(s) and tensioner you have still preserved the correct timing?
Old Apr 20, 2025 | 09:29 AM
Yes. It really was that simple.
Paul Jeeves
Feb 9, 2025 12:33 PM
George05
Jun 29, 2021 06:51 AM
TN8Shooter
Sep 30, 2012 09:16 PM
semyr19
May 15, 2011 08:54 AM
filoli1993
Dec 17, 2010 01:40 AM
