XJR wiring diagram help!
Old May 24, 2013 | 09:05 AM
Adam78's Avatar
Exclamation XJR wiring diagram help!
Hello all, So while troubleshooting my suspension issues, I have noticed that the module behind the rear seat is not getting any power. We cant seem to figure out which fuse goes to it (no fuse diagrams ANYWHERE in the car) We found a very low resolution copy of wiring diagrams online, but cannot make out some of the letters.
It is claiming that the brown/white wire is neutral...we think. Problem is, it is saying there are two plugs that say that. We can find only one plug with brown/white, and one with brown/orange. And two other plugs on the bottom, with one on the top. We are not getting negative to the brown/white cable. My dad (an electrician) wants to jump out the plug, but wants me to make sure it is the right plug (the one that gets that module its power) before we ruin anything else on the car...as if it were possible.
We think we may have a corrosion problem with the ground (a lot of rust on the metal in the seat thanks to these cars being as water tight as a sieve. Also if it is a ground issue, that may take credit for the myriad of other problems I'm having (Radio, GPS, A/C, Heat, DVD player, ect...) Any and all help will be greatly appreciated thank you. I will try to link up the schematic when I get the chance, low res as it may be, perhaps someone knows it by looking at it?
Old May 24, 2013 | 10:04 AM
Adam78's Avatar
Disregard! The god awful resolution on the schematics threw us through a loop. We read one of the colours wrong. We are in fact getting power to the module, now we are onto the ride height sensors. Wish us luck lol
Old May 24, 2013 | 10:06 AM
Adam78's Avatar
Does anyone have a quick trick to test the Ride Height sensors? We'll be checking the plugs from the module to see if they're getting power, but still is there a test we could do to solve this easier?
Forcedair1
Sep 8, 2025 01:57 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
DatDude
Sep 8, 2015 11:36 PM
danpop
XJ40 ( XJ81 )
Sep 8, 2015 03:23 PM
