89 XJ6 Blinker Problem
Old May 23, 2013 | 08:10 AM
Gluteous's Avatar
Default 89 XJ6 Blinker Problem
Howdy, brand new to the forum. With this '89 and its long laundry list I'm sure I'll be spending a lot of time here! First problem is with the RH turn signals. Both front and back have stopped working. The tail lights, brake lights, and flashers all work it is just the blinkers that don't. I found a popped fuse in the RH fuse bank and swapped in a new one but unfortunately...
I don't have a manual other than those that come with the car. Any advice would be appreciated.
Old May 24, 2013 | 03:10 PM
esloser's Avatar
This forum is for 2004-2010 xj's. I think one of the mods can move this to your year's forum - probably a better chance of someone being able to offer up some advice.
Eric
Old May 24, 2013 | 06:17 PM
34by151's Avatar
Sounds like it the stalk
You can get at the plug by
Remove the square plate on the lower dashboard under the steering column
Remove the upper and lower cover from the steering column
Now you can disconnect the plug
From the stalk plug measure the resistance
it will be 0 with nothing on and give a diferent reading for left and right turn
If you get nothing for the right turn you have your answer
If this is ok it is in the FEM or the Wiring to the FEM
34by151
Kevin Burnaby
Jun 28, 2020 08:04 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
