Yet another cooling fan question
Old Aug 28, 2016 | 05:16 PM
fredgarvinmp's Avatar
Default Yet another cooling fan question
Hello,
I have a 99 XJR The fans do not ever come on. I have read numerous threads about the fans. I am assuming that the fan relay controller is the issue?
If I understand correctly the fan control modules activate 2 relays 1 for each fan.
I am wondering if the 2 relays in the attached photo are the fan relays?
Also if I understand correctly the fan control module is buried somewhere under the left headlights?
What is the easiest way to access it?
Attached Thumbnails Yet another cooling fan question-img_20160828_125000.jpg
Old Aug 28, 2016 | 05:18 PM
PS I checked the fuses and they are good. I haven't had the opportunity to do the 100 ohm resistor test yet.
Old Aug 29, 2016 | 04:20 PM
I installed a 100 ohm resistor across the pins of the temp sensor plug and still no fans.
Old Aug 29, 2016 | 04:28 PM
Partick the Cat's Avatar
Sorry OM but you're in the wrong forum, this is the forum for 2003-09 XJs (X350).
You need to post in XJ XJ8 / XJR ( X308 ) - Forum
Ismael S
May 8, 2016 12:57 AM
dagny747
Apr 16, 2016 08:35 AM
Snookfever
Apr 9, 2016 02:05 PM
jamesackerman
Apr 4, 2016 03:47 PM
vincent661983
Apr 2, 2016 12:59 PM
