Which 02 sensor
Old Oct 17, 2011 | 11:20 AM
dsmith3435's Avatar
Default Which 02 sensor
Have a 1996 XJ6 vanden, won't pass emissions. I understand there are two 02 sensors. Should I replace both or which is more likely to be the troublesome one?
david
Old Oct 17, 2011 | 11:26 AM
Doug's Avatar
You have 4 oxygen sensors. No single one is more or less likely to be faulty. A scan tool would normally be used identify a faulty sensor.
Is your check engine light on? Were you told that you have a faulty sensor?
Old Oct 17, 2011 | 11:31 AM
dsmith3435's Avatar
Default 02 sensor
wife took the car in for state inspection. Check engine light was not on. I havent seen the report. mechanic just told me over the phone it was an 02 sensor...
thanks for your help and advice. guess with 4 I shouldnt tackle it. dunno
Old Oct 17, 2011 | 12:23 PM
dsmith3435's Avatar
will the readout from the state inspection tell me which sensor?
Old Oct 17, 2011 | 02:53 PM
sparkenzap's Avatar
No, it will not. In fact, there will be no difinitive information that it is indeed a sensor causing the failure. That requires analysis of the data from an OBD scan. Not to say the mechanic is not correct, just that there are other causes for most any emmision test failure besides the lambda sensors.
Do you have access to an OBD scanner? I find it somewhat hard to believe the X-300 will fail a emissions test without a OBD fault code. It will be helpful to know what parameter it failed, and what the allowable and actual values were.
Poet
Feb 7, 2025 02:18 PM
carl purchase
Oct 14, 2015 06:14 PM
Dave1109971
Sep 30, 2015 11:04 PM
Doug S
Sep 30, 2015 02:03 AM
