1995 XJ6 - Cooling Fan Relay Location
Old 08-13-2013, 07:13 PM
armccoy's Avatar
Default 1995 XJ6 - Cooling Fan Relay Location
The cooling fans on my 1995 XJ6 have stopped working. I suspect the issue is the cooling fan relay, but I've seen conflicting information about where it's located. The latest I've heard is that it's on the driver's side (American) in an area just in front of the tire and behind the headlamp and apparently, the only way to get to it is from under the the car.
Am I looking in the right place on this particular model?
Thanks!
Old 08-14-2013, 09:59 AM
armccoy's Avatar
Found it! In the cavity just in front of the driver's side (American) tire. Go in from underneath, remove the driver's side splash guard, and it's right there. Should be a white block relay. Hell of a place to put it, but there it was.
Hope this helps someone else looking for it!
razorboy (10-28-2013)
Old 10-28-2013, 08:29 PM
razorboy's Avatar
Awesome,
I have a project Jag XJ6 and discovered the fans not working today. Nice tip and I will dig into mine tomorrow.
Bernie
Old 10-29-2013, 05:35 AM
SleekJag12's Avatar
Thanks for bringing this back up Bernie, good job. Wonder if Mccoy's fans ever came back on?
Kevin Burnaby
06-28-2020 08:04 AM
rusty37
04-05-2020 07:40 PM
JimMLiny
09-09-2015 08:13 PM
XJsc-guy
09-02-2015 11:43 AM
Quick Reply: 1995 XJ6 - Cooling Fan Relay Location
