1995 XJR Stopped running abruptly
Old Jan 20, 2008 | 09:10 PM
FactoryJaguarTech's Avatar
Default RE: 1995 XJR Stopped running abruptly
If chain was loose and you let off gas at that kind of rpm, then the slack would cause a timing concern yes.
Old Sep 29, 2008 | 06:18 AM
Brutal's Avatar
if youve checked for vacuum leaks and have none the lean code is almost always cause by a intermittent mass air flow sensor fault. another thing, pull off the throttle body and clean it with carb cleaner and tooth brush and pay attention to the idle air control solenoid and ports. If you have oill and carbon buildup on either or both it can lead to dying on sudden throttle closure if the IACS cannot comphesate fast enough to give air to the engine when the throttle slams shut, and with buildup around the throttle blades you no longer have a physical clearance that lets air around as it is only controlled by the IACS. So clean it and eliminate this as a cause, and on your tensioner, yopu cannot install it unless you have rotated it in to where it locks for installation. These tensioners seldom fail like the V8, but if you have the original with a steel cam shaped plate over it then do replace it as there has been an updated tensioner that is a 1 piece cover out for years
Old Oct 2, 2008 | 10:26 AM
oldmots's Avatar
This is a typical symptom of a bad crank position sensor and it will not show up in the codes. I would put in a replacement. The lean code could be a number of things, the MAF as was already noted, the upstream O2 sensors, and an intake or vacuum leak. Take a look at the intake booting for gaps or loose or damaged vacuum hoses.
Old Oct 2, 2008 | 10:28 AM
oldmots's Avatar
I forgot to mention that the ECU relay could be failing, check it too.
Old Dec 2, 2008 | 10:39 PM
4running's Avatar
Why would the ECU relay initiate a lean code? I am a bit of a novice here.
Forcedair1
Sep 8, 2025 01:57 PM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
tberg
Sep 7, 2015 07:32 AM
d a
Sep 3, 2015 02:34 AM
