1996 Xj6 Belt Map
Old Jun 23, 2024 | 03:26 PM
Moves_like_jaguar's Avatar
Default 1996 Xj6 Belt Map
Hey gents, first post here!
Hoping to get some help here, looking for a belt diagram and hopefully some assistance on what belts I need.
i took my car to the shop for a new alternator a few weeks ago and had it returned with no belts on it. I’m giving up having people work on my car so I’m just going to put belts on myself.
any assistance would be great, really pulling my hair out here trying to find what I need
Old Jun 23, 2024 | 04:12 PM
Parker 7's Avatar
Have a Jaguar belt part # diagram somewhere
EBC11306 / 39.24 inch x 5 ribs
You will not have the 3rd supercharger belt but grouped as in this link
Genuine Drive Belts-3.2/4.0/4.0 Litre Supercharged (3.2 Litre,4.0 Litre,4.0 Litre (california),4.0 Litre Supercharged) For Jaguar Xj 1995 - 1997 (from 720125 To 812255) (x300) Classic | Jaguar Land Rover Classic Parts
Welsh out of Ohio USA has good shipping as experienced
Search (welshent.com)
The garage probably had a stuck alternator belt tensioner rod / shaft that you can remove from the engine block by 1 bolt , 10 mm , clean the threads with a wire brush on a vice and work in some penetrating oil , may have to put heat on the threaded block on the tensioner rod / shaft
The alternator long pivot bolt is 15 or 17 mm on each side , there is 1 shouldered short ( one engine mount clevis ear ) bushing in the pivot that stays in place , this has to be done from underneath as may need to loosen first
The A/ C compressor belt tensioner adjustment is a whole different story , do not strip the 4 sided head of the adjustment long bolt
There is 1 / 5 amp small fuse that is missed on alternator issues as it takes power to make power ( winding excitation )
Fuse # 10 right engine bay fuse box
Old Jun 23, 2024 | 04:40 PM
b1mcp's Avatar
This is an annotated picture from Jag Parts diagram.
https://parts.jaguarlandroverclassic.../brand/jaguar/
Assuming you do not have supercharger then you need an Alternator belt (Blue) and an AC Compressor belt (Red). The other belt and pulleys are Supercharged only.
Mr.Hotrod
Nov 19, 2020 09:51 PM
Jaguar Dre
XJ40 ( XJ81 )
May 18, 2017 12:45 AM
dhferry1
Nov 30, 2013 12:25 PM
rupertle
XJ40 ( XJ81 )
Mar 1, 2012 11:24 AM
