1996 XJR 5-6 cylinders ar not working
Subscribe
Feb 24, 2024 | 04:30 AM
Hello Guys,
I have a situation that engine is operating only on 4 cylinders.
Coils, sparks, injectors are checked by swaping them in to different places.
Coolant temperature sensor is operating as well.
Any ideas what to do next? What can cause such problem?
Reply 0
Feb 24, 2024 | 05:05 AM
I have had a similar problem. It relates to cars being driven around town and no high-speed running.
There is a service bulletin relating to exhaust valves not seating due to exhaust residue build up caused by this sort of running.
Take it out on the open road and give it a serious thrashing.
I did about 80 ks at high revs in intermediate gears to burn off this residue.
Reply 0
Feb 24, 2024 | 06:53 AM
In your spot of stumble under the bonnet ......................
The coil wires can easily be on the wrong place on the rear most # 6 and # 5
The # 6 has the Light Green / Purple wire
The # 5 has the Light Green / Orange wire
See Moderator Don B's post # 47
P0300 and P1313. Here we go - Page 3 - Jaguar Forums - Jaguar Enthusiasts Forum
and
05-1-36 Replacing MAF.pdf (jagrepair.com)
and
03-1-10 Intermittent Poor Idle.pdf (jagrepair.com)
See bottom right corner of the pic below
Reply 0
Feb 25, 2024 | 03:20 AM
Check that you haven’t swapped the wiring around for coils 5 and 6. A very very common mistake, which the layout of the wiring and the connectors almost invites you to make.
Reply 0
Feb 25, 2024 | 05:21 AM
Quote: In your spot of stumble under the bonnet ......................
and
and
Hello,
Thanks for guidelines. Problem was with swapped spark plug wires. Car is working correctly now!
Reply 2
Subscribe
Currently Active Users (1)
