1996 XJR 5-6 cylinders ar not working
Old Feb 24, 2024 | 04:30 AM
kestaszn's Avatar
Default 1996 XJR 5-6 cylinders ar not working
Hello Guys,
I have a situation that engine is operating only on 4 cylinders.
Coils, sparks, injectors are checked by swaping them in to different places.
Coolant temperature sensor is operating as well.
Any ideas what to do next? What can cause such problem?
Old Feb 24, 2024 | 05:05 AM
Bill Mac's Avatar
I have had a similar problem. It relates to cars being driven around town and no high-speed running.
There is a service bulletin relating to exhaust valves not seating due to exhaust residue build up caused by this sort of running.
Take it out on the open road and give it a serious thrashing.
I did about 80 ks at high revs in intermediate gears to burn off this residue.
Old Feb 24, 2024 | 06:53 AM
Parker 7's Avatar
In your spot of stumble under the bonnet ......................
The coil wires can easily be on the wrong place on the rear most # 6 and # 5
The # 6 has the Light Green / Purple wire
The # 5 has the Light Green / Orange wire
See Moderator Don B's post # 47
P0300 and P1313. Here we go - Page 3 - Jaguar Forums - Jaguar Enthusiasts Forum
and
05-1-36 Replacing MAF.pdf (jagrepair.com)
and
03-1-10 Intermittent Poor Idle.pdf (jagrepair.com)
See bottom right corner of the pic below
Old Feb 25, 2024 | 03:20 AM
countyjag's Avatar
Check that you haven’t swapped the wiring around for coils 5 and 6. A very very common mistake, which the layout of the wiring and the connectors almost invites you to make.
Old Feb 25, 2024 | 05:21 AM
kestaszn's Avatar
and
and
Hello,
Thanks for guidelines. Problem was with swapped spark plug wires. Car is working correctly now!
MathisJag-2000
Jul 25, 2023 08:07 PM
Eddiec
Jun 17, 2021 08:03 AM
Ipc838
Oct 4, 2012 04:06 AM
mevans
Apr 22, 2012 08:20 AM
SoTxXjr
Nov 21, 2009 04:07 PM
