Are Ignition coils swappable from 1999 XJR and 2000 XJR
Old Jul 25, 2023 | 12:59 PM
MathisJag-2000's Avatar
Default Are Ignition coils swappable from 1999 XJR and 2000 XJR
Simple Question I have a 1999 could be a 1998 XJR that engine died and my other 2000 XJR needs an engine coil can I just swap them without issue I don't see any problem, but this forum knows all so might as well ask.
Old Jul 25, 2023 | 01:48 PM
Vauxi's Avatar
2000 should be aj27sc and older a aj26sc engine. Coils on those do not mix.
Old Jul 25, 2023 | 04:35 PM
motorcarman's Avatar
The North American 1999MY XJR is AJ26 as is the 1998MY XJR.
2000MY XJR up to 2003MY is AJ27.
The Normally Aspirated 1999 XJ8 is AJ27 (up to 2003MY) so the coils are completely different.
AJ26 = 2 pin
AJ27 = 4 pin
Old Jul 25, 2023 | 06:10 PM
AJ26 = 2 pin
AJ27 = 4 pin
Whats the essiest way to tell the difference from each engine?
Old Jul 25, 2023 | 06:27 PM
AJ26 = 2 pin
AJ27 = 4 pin
Old Jul 25, 2023 | 07:28 PM
AJ26 = 2 pin
AJ27 = 4 pin
I mean without removing a ignition coil is there anything different visually on the engine it self to tell the difference form one another? Like so I can know if it's an AJ26 or AJ27?
Old Jul 25, 2023 | 08:04 PM
nilanium's Avatar
No throttle cable on the AJ27S?
Old Jul 25, 2023 | 08:06 PM
Addicted2boost's Avatar
If it’s an AJ26/S, there will either be a large chrome or black vacuum container right next to the throttle body. If you still aren’t sure, just pull the ignition coil cover off and if it has 2 wires going to each coil, it’s a 26 engine. If it has 4 wires it’s a 27 engine. The above posters already mentioned this.
Old Jul 25, 2023 | 08:07 PM
All the X308’s had throttle cables.
Noma Auto Parts
Jun 6, 2023 05:18 PM
electrovolt
Aug 1, 2014 05:22 PM
GerryXJR
Feb 18, 2013 08:42 AM
Ipc838
Oct 4, 2012 04:06 AM
james henry
General Tech Help
Jul 22, 2012 10:17 AM
