1997 XJ6 4.0L at the junkyard
There’s a 97 XJ6 4.0L at the junkyard. I haven’t gotten too much into it, but I am wondering what parts I could pull off of it that could be useful to have tucked away in the garage in case I ever need it. Any ideas? I have a 97 XJR6 so I figure not all parts are interchangeable?
the front end is missing except for the bonnet and grill which seems to be in decent condition.
I have pulled all the relays from the boot and in the engine bay. As well as the headlamps, clock unit, kick down switch and dash defrost vents.
Not everything inside is in good condition. Someone has already gotten inside and unfortunately destroyed some parts in attempt to get what they wanted.
some that come to mind are: dimmable rear view mirror if in good condition, window switches, gearstick plastic surround (they usually break when removed), vents if they they have good tabs, rear parcel shelf if it has a subwoofer opening, abs wheel sensors, MAF.
exhaust manifolds if they are uncracked, and exhaust shield if it is chrome and in good condition.
yeah, my list was mainly just stuff thats always in demand, and easily resellable, not specifcally XJR6 compatible parts.
Grab the ignition coils, especially if they are the original Lucas-branded ones (Made in Japan by Diamond Electric Mfg. Corp.). I think they will fit your engine, but if not, someone always needs them so they'll be easy to sell. One of my friends just bought a complete set and paid $35 for each coil.
Other items I can think of:
Fuel Injectors
Camshaft Position Sensor
Camshaft Cover
Center Console Arm Rest / Cupholder (even if it's not the correct color for your car, the cupholder can be used to repair yours if you ever need to)
Lug Nuts - 2 or 3 of the nicest ones from each wheel
Gear Shift knob
Radio
Radiator Fan/Shroud Assembly
Ignition switch
Turn Signal Switch
Wiper/Washer Switch
Bonnet Leaper
Brake Master Cylinder & Booster
Windshield Wiper Motor
Probably a lot more!
Cheers,
Don
Fuel Injectors
Camshaft Cover
Gear Shift knob
Radio
Ignition switch
Turn Signal Switch
Wiper/Washer Switch
Bonnet Leaper
Cheers,
Don
