1997 XJ6 lefthand drive ABS plug
Subscribe
Oct 27, 2014 | 01:55 PM
Hi
The connector plug to my abs pump has let the two wires slip through.
One is grey or olive color one is red. I am trying to reconnect the wires to the pump. I am facing the pump from the passenger side . Should the red wire plug into the left connector on the pump and the olive/grey wire plug into the right connector on the pump or the reverse. I know this seems like a no brainier but I want to make sure it's is right.
Sorry..and thanks for any assistance.
Reply 0
Oct 27, 2014 | 02:01 PM
Welcome to the forum Joedudejag,
I've moved your question from General Tech Help to X300 forum. Members here with the same model will be able to help.
Reply 1
Oct 27, 2014 | 02:09 PM
Thank you Graham.
I will read posting rule and follow.
Reply 0
Oct 27, 2014 | 02:42 PM
Welcome to the forum Joe. On my 95, I have to look over the top of the pump to see the connection, must be a different setup. The red wire is on top but that probably doesn't help you.
Reply 0
Oct 27, 2014 | 02:48 PM
Thank you. So looking down from the top the red wire is closer to the firewall?
Reply 0
Oct 27, 2014 | 02:55 PM
No, it's directly above. Like I said, must be a different orientation.
Reply 0
Oct 27, 2014 | 03:14 PM
Thanks for the info
Reply 0
Subscribe
Currently Active Users (1)
