1997 XJ6 problem with lights in trunk
Old Mar 15, 2010 | 04:32 PM
freeJT2010's Avatar
Default 1997 XJ6 problem with lights in trunk
The luggage compartment lights in my 97 XJ6 come on when the trunk is opened up, but go off once the trunk lid gets about half way up. Shouldn't they stay on when the trunk is open all the way? What's the fix?
Old Mar 16, 2010 | 01:20 AM
jagqueen's Avatar
you will most probably find a broken wire in the loom of cables which is inside the plastic piping attached to the right hand boot hinge. Detach the cable ties a to loosen the tension on the cables and wriggle them. Chances are you'll find the light going on and off.Isolate the broken cable and rejoin it.
Old Mar 17, 2010 | 08:35 PM
freeJT2010's Avatar
Thanks, Jagqueen. Your analysis was spot-on. I wiggled the wires, and was able to make the lights go on and off. Just need to isolate and repair the broken one. I'll report back when complete. Thanks, again.
Jim
Old Mar 21, 2010 | 03:01 AM
panchostatus's Avatar
just had to do that with mine. 4 wires broken, tag lights & boot lights were disabled.
anyone know of an economical/relatively easy (nothing is easy) fix for the entire harness?
all the wires in there were brittle and looked ready to break in half.
I shaved off some of the plastic sleeve to give the harness a little extra breathing room also.
my method of cutting/replacing sections has given me good results, but I really don't feel like cutting/soldering/splicing the entire trunk harness.
thanks
-pancho
kenatofc
Oct 27, 2015 06:48 AM
reedmtn
Aug 31, 2015 12:48 PM
201motels
Aug 30, 2015 08:03 PM
rwoodlin
Aug 29, 2015 04:32 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
