64,000 mile maintenance to check for ?
Old Nov 9, 2014 | 11:11 AM
weisberg's Avatar
Default 64,000 mile maintenance to check for ?
My 1997 XJ6 goes into a shop tomorrow for inspection of what they think the car needs in regards to the 60k service and anything else. They are the area specialists for Mercedes and ZF transmissions that other shops outsource to, and they say others often replace things that are just fine. I am not a perfectionist for appearance but I savor a well running vehicle. My goal is to keep this car a decade as my daily driver over city roads, 5,000 miles annual use.
Here is a short list of items I have culled from other posts. Please let me know if there are other items
1. gearbox fluid and back axle (this scared off 2 other local shops)
2. Upper tensioner in the engine (for XJR only or regular XJ6 too?)
3. Quality oil: run 10W/40 Synthetic oil
4. "bushes for the radiator mounts, and condensor mounts are probably getting tired"
5. Traction Control Actuator's two wires insulation checked
6. Shocks and related yellow bushes
7. Front suspension wear that would justify switching to Andy's front anti-roll bar drop links
Old Nov 9, 2014 | 12:49 PM
Doug's Avatar
Scared off? I wonder why. Fluid changes are boringly routine on the gearbox and differential. Nothing exotic at all.
Same for either engine as far as I know. Replace only when/if needed.
Good
Inspect, repair/replace as needed
Not quite sure what you're asking or saying. Andy's drop links are an optional upgrade. Suspension wear, or lack of suspension wear, doesn't really enter in.
Don't forget fuel filter, repacking front bearings, belt inspection, lubricating half-shaft u-joints, fresh coolant.
Others will chime in with more!
Old Nov 9, 2014 | 05:35 PM
jagent's Avatar
Whilst they are working on the back end (changing diff oil etc) have them do a quick visual on the Jurid Coupling. At 60K yours may be fine, but they form cracks over time and ultimately fail if neglected.
Old Nov 9, 2014 | 07:53 PM
al_roethlisberger's Avatar
Question Jurid Coupling
Where is this on our X300s?
Old Nov 9, 2014 | 08:05 PM
Doug's Avatar
It the rubber disc that joins the differential yoke to the driveshaft.
Item #5 in the illustration:
http://www.jaguarclassicparts.com/uk...omatic-gearbox
Old Nov 9, 2014 | 08:33 PM
jagent's Avatar
It is a possible DIY job, but I believe the tail shaft is a little awkward to drop on this model especially without a hoist or scissor lift. I have neither. I had mine done at the same time as having the diff pinion seal replaced (which was leaking). Sometimes it's worth consolidating a coupe of jobs requiring similar component dismantling to save on time/labour cost!
Old Nov 9, 2014 | 09:54 PM
weisberg's Avatar
Thank you fellas, hopefully this shop will appreciate my succinct list culled from your suggestions!
If not, I like knowing what to have checked off and demonstrated.
Forcedair1
Sep 8, 2025 01:57 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
meanman
Aug 7, 2016 10:15 PM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
