96 XJ Pollen Filter
Old Jan 4, 2014 | 06:18 AM
adam_51's Avatar
Default 96 XJ Pollen Filter
Hi all
I'm new to the Jag scene and was wondering if the 96 XJ has a pollen filter and if so where it is located as the heater on my seems to not be that good - I have replaced the thermostat as well and coolant.
Adam
Old Jan 4, 2014 | 06:36 AM
Welcome to the real world.
No idea which Blackburn you call home. Is it the one in OZ, or UK, or maybe somewhere else?? Dont forget WWW means World Wide Web, and that is a huge place.
The locale of the car dictates the market, and most importantly, the features fitted by the factory for that market
My 96 X300 has NO pollen filter, which I believe is consistent with Aussie cars.
Old Jan 4, 2014 | 07:20 AM
adam_51's Avatar
UK
Old Jan 4, 2014 | 07:53 AM
AllanG's Avatar
As Grant says, no cabin filter.
Poor heater performance is a fairly common affliction for these cars. There could be a number of causes and as you have already changed the stat, these would be my first things to check.
1. Blocked heater core. Unhook the hoses and try back flushing the core. If little to no water comes out the, core is probably blocked. Not easy to clear and generally means pulling out the core which is a pain.
2. Inoperative water valve. Put your hand on top of the valve and see if you can feel the solenoid cycling on and off. They get stuck so sometimes giving them a whack with a rubber mallet often does the trick. Best though to take it out and dismantle and clean. It is relatively easy to work on.
3. Inoperative electric heater water pump. Even if you can feel the the motor spinning, it does not mean that the vanes are moving as the impeller is connected to the motor by a magnetic coupling. The impeller can get clogged so you will need to dismantle and check. If the motor is not turning, the brushes may be worn.
It'll keep you off the streets for a day
Old Jan 4, 2014 | 08:02 AM
adam_51's Avatar
Ok will look into that
Old Jan 4, 2014 | 08:59 AM
AllanG's Avatar
Oh and I forgot to mention, there is also a fuse for the heater water pump located in the left side engine bay fuse box. I'd check that first.
kthrash
Feb 25, 2019 10:20 AM
redxk8
Oct 4, 2015 08:28 AM
reb1999
Sep 26, 2015 08:41 AM
SD96XJ6L
Sep 25, 2015 10:53 PM
