96 XJR security/starting issue.
Old Apr 15, 2010 | 01:05 PM
supergordo's Avatar
Default 96 XJR security/starting issue.
Hi everyone.
I'm working on a 96 XJR. I'm helping a friend get this in shape.
The main issue that we're working thru is a no start issue. It has a brand new battery FYI.
The car started and ran fine until on day my friends nephew left the door open and it totally drained the battery. After recharging the battery it would crank but not start. He had a mechanic come out and work on it and the guy bypassed something in the steering column with a relay and it starts now. However the by product of this workaround is that if you don't drive it everyday it drains the battery.
Is there a security system or procedure that needs to be performed after totally draining the battery? Could it be a built in kill system?
I'm sure you are all way more familiar with this than I am. I know cars well, but I am not familiar with the Jaguar systems.
Thanks in advance!
Gordon
Old Apr 17, 2010 | 12:31 PM
supergordo's Avatar
bump ttt
99xk8guy
May 28, 2024 09:36 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
scooternva
19
Oct 27, 2015 02:14 PM
Ipc838
Sep 13, 2015 03:27 PM
vincent661983
Sep 10, 2015 05:52 PM
