97 Sovereign - help
Old May 2, 2008 | 08:13 PM
jag_genius's Avatar
Default RE: 97 Sovereign - help
it has traction control for sure.. if the trac button is there on the far left and i think sports button is there also.. then the sprot button is for transmission and trac is for traction control
Old May 8, 2008 | 03:07 PM
Jaybo242000's Avatar
Yes sir-
the sport light means the transmission is in Sport mode, the revs will be a little higher before shifting, for a more sporting feel to the car, it's going to hold gears longer. If the trac light is on it should have to do with the traction control, eithern it is experiencing some sort of malfunction or you have it turned off. I hope this helps my friend
-James
jimforrest (uk)
Feb 28, 2019 06:42 PM
Real Sinner
XJ40 ( XJ81 )
Sep 24, 2015 10:00 PM
XL391
Sep 24, 2015 08:24 PM
prettydaim
Sep 10, 2015 04:27 AM
