ABS wiring diagram for XJ6 1997
Old Aug 6, 2018 | 09:09 AM
annamiata's Avatar
Default ABS wiring diagram for XJ6 1997
I daughter was involved in a car accident. As the result, the ECU wiring harness was pull away from the ECU. Several wires were breached which I repaired by soldered and heat wrapped. However, I now have Anti lock warning and speedometer is not working. This wire is located under the passenger front fender that T off to ABS pump and to ECU.
I suspected some other wires in the wire loom have internal damaged/breach but I do not know which one. I bought a used wire loom from a 1995 XJ6 but it was not the same.
Is someone here have a wire diagram for 1997 XJ6?
Old Aug 6, 2018 | 10:46 AM
Lady Penelope's Avatar
http://www.jagrepair.com/images/Auto.../jagxj1997.pdf\\
Seee page 72
The LS3 and RS3 xonnectors are a pain in the butt . Don't try too hard and break the lock pins .This is the best I came up with as a connector map
Has anyone run across a connector part # or at least the pins ?
Old Jun 25, 2019 | 06:28 AM
Stu Jags's Avatar
Hi, just reading this post about ABS fault, it mentions a wire in passenger side fender (bumper)
im guessing passenger side could mean Right hand side when sitting in the vehicle ? What wire is this, I have ABS fault that has appeared after changing AC compressor and am thinking that mechanic might have disturbed this wire as he was working under right hand side trying to remove AC pump.
looops
Aug 25, 2015 10:21 AM
spike47
May 13, 2012 05:03 AM
invicta
Interior
Aug 23, 2009 10:48 PM
