AC Blow Cold & Heat same time
Old Sep 18, 2013 | 08:50 PM
rjaguar's Avatar
Default AC Blow Cold & Heat same time
Hi Folks,
I have my 1997 Jaguar XJR, that AC Blow very cold air from driver side & heat or just air from passenger side, I thought in the beginning this problem cause by the Exhaust manifold cause they been cracked both front & rear, after I fixed them, AC still blow air one side colder than the other.
the car is Solo Climate Control not Dual!
Any advise?
Thanks.
Rabeea
Old Sep 18, 2013 | 09:19 PM
avioni's Avatar
Mine does the same. Someone here told me its caused by low refrigerant. But i cannot tell you this is whats happening because when i went to fill it up the tech told me it had a bad expansion valve. So im stuck with that problem for now. Please post if you fix this
SD96XJ6L
Jan 12, 2022 04:30 AM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
tberg
Sep 7, 2015 07:32 AM
Bcrary3
Sep 3, 2015 03:48 PM
OkieTim
Sep 2, 2015 12:48 PM
