Advice re paint matching
Old Mar 18, 2020 | 03:11 PM
X300exec's Avatar
Default Paint advice
I have bought some matched paint in jgz840 Antigua mica metallic and on the grey undercoat supplied with it it comes out way too dark,would this paint have used white undercoat as when painted directly on white paper it’s a much better match ??
#confusing
Old Mar 22, 2020 | 04:42 PM
steven300's Avatar
grey primer from factory,but white primer is made and can be used if it tints better for you. high poly colors are allways hard to match
Old Mar 22, 2020 | 10:43 PM
Allycat's Avatar
Did the paint supplier you purchased from offer any other variants to the shade or a recommended primer colour?
Depending on what mixing scheme/paint brands there can be different numbers of shade variants available.
I have also found that waterbase formulations can be better matches than solvent formulations.
Old Mar 23, 2020 | 12:41 AM
X300exec's Avatar
He has asked me to leave the petrol flap with him so he can match it that way
Old Mar 23, 2020 | 03:08 AM
Allycat's Avatar
I would go back to him and supervise his colour matching procedure and ask some questions with regard to variants and undercoats.
I have known paint suppliers to take the easy route in not checking the panel in the correct light, if its raining outside or they don't compound the the test panel etc
It would also be good to check the colour against the areas of the car you are blending to.
Some colour mixing schemes offer only one formulation for a particular colour while another scheme can offer many......weird i know, but that's just the way it is.
Are you going edge to edge with the new colour or doing a blend into the next panel?
Old Mar 23, 2020 | 03:18 AM
X300exec's Avatar
Only painting the lower front wing piece,behind mud flap and below body trim
Old Mar 26, 2020 | 02:35 AM
X300exec's Avatar
Default Advice re paint matching
Ive now had three different companies ‘match’ me a tin of Antigua blue jcz mica and all were too dark and it’s starting to get annoying ,my car is a 1997 and the paint mix just doesn’t match ,it’s never been resprayed and I just don’t understand the issue ,I e had paint mixed for my old kingfisher green or blue one years ago and it was perfect ,any advice please
Old Mar 26, 2020 | 04:42 AM
I assume that's a typo - Antigua Blue is JGZ.
The colour of your car will have changed slightly with 23 years of exposure to the elements and possibly even some sunshine that far south!
Modern paint blending machines are very accurate but a batch of original JGZ could therefore no longer exactly match the car. A spectrophotometer used directly on the vehicle panel can match the original code and then allow slight variations in the paint components mix to account for weathering. Downside is having to take the vehicle to a paint supplier or a bodyshop with a spectrophotometer to have it matched.
Old Mar 26, 2020 | 04:43 AM
X300exec's Avatar
Finding one of those in Suffolk should be fun 🤦‍♂️
Old Mar 26, 2020 | 06:19 AM
Cafcpete's Avatar
Try talking to these guys (once the virus is over!) in Ipswich.
https://www.ippsltd.co.uk/colour-mat...-spectrometre/
They might want the fuel flap of a mirror cover, or they might just look at the car in the flesh.
I have not used them but recommend form another forum.
Spectrophotometer Car Paint Matching In Suffolk? - Bodywork, Paint and Detailing - The Mini Forum
Old Mar 27, 2020 | 02:46 AM
X300exec's Avatar
Default Paint restoration at home
I’m getting good results with those clay bar pads and paint protection liquid ,it’s take a while and a couple patches need paint but they will be done when I find a decent match ,Anybody
else done theirs at home
Old Mar 27, 2020 | 04:45 AM
Cafcpete's Avatar
Funny you put this up, as I am going to be trying out a Clay Cloth on mine this morning.
https://www.theclayclothcompany.co.uk/page_3169237.html
I shall post pictures when done
Old Mar 27, 2020 | 05:37 AM
Allycat's Avatar
I have just started mine. I only had chance to do the bonnet until my next 4 days off. Looks like your doing a great job.
Old Mar 27, 2020 | 06:16 AM
X300exec's Avatar
What colour is that it’s awesome and I’ve not seen it before 😳
Old Mar 27, 2020 | 09:12 AM
Cafcpete's Avatar
Ok I have only done the boot, bumper and rear wings.
My car was pretty good as I had only polished it a couple of weeks ago but wanted to play with my new clay cloth.
I had never used clay before but it was very easy and made the bodywork silky smooth. Very please with the result.
From start to finish it took about 1 1/2 hours, but that is just a 1/3rd of the car!
Beginning. Washed before claying.
Clayed and polished.
Clayed, polished and waxed
Finished. At least the rear!
Old Mar 27, 2020 | 09:13 AM
Allycat's Avatar
Thanks, it is radiance red
Old Mar 27, 2020 | 09:16 AM
X300exec's Avatar
No wonder I hadnt seen it on an x300 😂
nice colour tho 👌🏻
Old Apr 1, 2020 | 10:42 AM
Don B's Avatar
Hi X300exec,
I have merged your THREE threads on this topic into ONE. Please do not start any more threads on this topic. Having all of your posts and others' replies in one thread helps prevent confusion and double and triple effort on the part of other members who want to help.
Cheers,
Don
Old Apr 1, 2020 | 10:59 AM
X300exec's Avatar
They were not all on the same subject ,one was about detailing at home 🤦‍♂️
Old Apr 1, 2020 | 01:33 PM
Don B's Avatar
The title was something along the lines of "Paint repair at home," and your post contains the words, "...a couple patches need paint but they will be done when I find a decent match ,Anybody"
If you'll tell me which post numbers you think should be in a separate thread I'll be happy to consider moving them.
Cheers,
Don
