air con
Old Jun 26, 2010 | 11:41 AM
madfred's Avatar
Default air con
hi im having trouble with air con sensor on my x300 4 ltr have had system tested and regas but still blowing warm they say it could be the sensor, any help please, i live in york u/k
Old Jun 26, 2010 | 12:28 PM
Gus's Avatar
Gus
See if this information helps http://www.gusglikas.com/images/Auto...s/ACSystem.pdf
http://www.gusglikas.com/images/Auto...or%20Codes.pdf
Old Jun 30, 2010 | 11:15 AM
bhmaxjag's Avatar
Is your compressor clutch kicking on? If not then I'd suspect your pressure switch. However if the clutch was not kicking on prior to having your system recharged I would wonder how the shop was even able to charge it
Old Jul 2, 2010 | 04:45 AM
madfred's Avatar
Default air on
hi gus, mad fred, here have done what you suggested coming up code no"s 12 23 24 but have had front bumber of to fit new front wings maybey that has not helped , but thats why my "mates" call me mad fred
Old Jul 11, 2010 | 08:49 AM
madfred's Avatar
hi mate how right you are about my system have had it checked out by aircon expert system just of vapour and has buggered compresser so now having to find a compresser for it that will not be cheap but will cure problem, will let you know outcome
Old Jul 11, 2010 | 09:24 AM
Gus's Avatar
Gus
I am not an A/C expert but recently found that my A/C was not working. The fuse was good and the relay was replaced thinking it was not working properly preventing the A/C clutch from engaging. The problem ended up being the 4-Level pressure switch. It is my understanding that this pressure switch controls not only the compressor but the cooling fans as well. This switch prevented power to the clutch of the compressor and cooling fans when the A/C was turned on.
scooternva
29
Mar 25, 2025 12:45 PM
scooternva
19
Oct 27, 2015 02:14 PM
mel
Sep 20, 2015 04:56 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
tonyforman
Sep 10, 2015 07:23 PM
