Air con recharge
Old May 1, 2011 | 01:41 PM
109muntaz's Avatar
Default Air con recharge
Hi
I am going to recharge my air con this week, before i do i need someone to confirm where the correct place is to recharge. Is the service port the port nearest the front of the car furthest from the condensor?
Many thanks
Old May 1, 2011 | 03:45 PM
biffta's Avatar
Originally Posted by 109muntaz
Hi
Many thanks
Not sure if the one you quote is the correct one, but your post suggests YOU are going to do the job yourself. If so, surely you should know? Alternatively if a 'specialist' is doing the job then surely they should!
Old May 1, 2011 | 04:43 PM
Simprof's Avatar
The suction/return line is larger than the High pressure side. You need to charge the system via the low side (Suction/Return) just follow the larger line from the compressor and your run in to the filling valve...
Old May 1, 2011 | 10:12 PM
jagman96's Avatar
the port right there on the mini beer keg
Old May 3, 2011 | 10:16 AM
xjrguy's Avatar
I LIKE the way you think, Jagman!!
Cheers,
Old May 3, 2011 | 12:25 PM
poor boy's Avatar
Default Yeah!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Cheers,
Me too Jagman. By the way 109MUNTAZ, it would appearr you are a "Newbie" so
Welcome to the forum!!!!!!!!!!!!!!!!!!
I think you'll find everything very informative and the members more than willing to help where they can. So log on often, buckle up, and enjoy the ride. Poor Boy
scooternva
29
Mar 25, 2025 12:45 PM
scooternva
19
Oct 27, 2015 02:14 PM
mel
Sep 20, 2015 04:56 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
tonyforman
Sep 10, 2015 07:23 PM
