AJ16 throttle body bolt spacings
Old Apr 24, 2013 | 06:01 PM
Jagboi64's Avatar
Default AJ16 throttle body bolt spacings
If anyone happens to have a AJ16 4.0/3.2 throttle body handy ( not supercharged) could you measure the attaching bolt spacings please? I'm wondering if it would fit on the earlier Series 3 XK 4.2 manifold for a megasquirt project I'm contemplating.
The AJ16 TB seems the easiest way to get the throttle position sensor and a slightly larger throttle in the process.
Old Apr 25, 2013 | 12:38 PM
jeremiahjaguar's Avatar
Tb on the sc or na car bolt up the same except the coolant hose connections are in a different place. take a look at a sc tb i bored out, it is huge, this is good for all out racing applications. Had to take it off because i do mostly city driving and it was a pain to control for stop and go driving as you had to baby the gas pedal, but was great for all out racing. 7.7 cm width and 9cm length, measured from outer edge to outer edge of bolt pattern/hole. the center pic shows how much larger the bore is with the old plate inserted over the new plate for comparison.
Attached Thumbnails AJ16 throttle body bolt spacings-photo-1-.jpg   AJ16 throttle body bolt spacings-img_2684.jpg   AJ16 throttle body bolt spacings-img_7208.jpg
Old Apr 26, 2013 | 02:06 PM
XJRengineer's Avatar
The bolt spacing is 64mm between centres in one plane and 77mm in the perpendicular plane. I know these values are accurate, as I've machined and adaptor to fit the throttle body and used these values.
Old Apr 26, 2013 | 11:10 PM
thanks for the corrections, my mind must have slipped when taking measurements. sorry for the foul up.
Old Apr 27, 2013 | 09:18 AM
Jagboi64's Avatar
Thanks very much, that should work well for me. Slightly different than the XK manifold, but close enough I can make it work.
xjrjag
Oct 24, 2024 03:09 PM
Gus
Oct 15, 2019 12:29 PM
ajacks86
Oct 12, 2017 08:51 PM
mrplow58
Sep 9, 2015 11:27 AM
