Antenna?
Old Jun 2, 2014 | 07:41 PM
ziggydrives's Avatar
Default Antenna?
Hey guys well here's a new one, car is running great and so far all looks good mechanicaly. However my new prob, is the antenna, It some times comes up when I turn on the radio, or some times, does not. It's getting frustrating. Any way I was told to clean it and rub it with a little lighter flued to clean it and that it wuld just disipitate in a few seconds. So still no help, The antenna still chooses when it wants to come up or not. mostly not! Is this a mechanical problem with the motor or the antenna itself...any one else have this problem. And of course when the antenna is not up, I can't get anything...SO as I said very frustrating to say the least...????
Old Jun 3, 2014 | 02:23 AM
I've moved your question from General Tech Help to X300 forum. Members here with the same model will be able to help.
Old Jun 3, 2014 | 03:43 AM
Suede's Avatar
Remove the power Antenna unit for inspection.
1) Pry back the carpeted cardboard in the trunk to expose antenna.
2) Unplug the power antenna wiring harness.
3) Unbolt Antenna grounding strap.
4) Unbolt 2 bolts securing the antenna.
Inspection:
1) Lay Antenna unit on it' side with the screws faced skyward
2) Remove the screws securing both halves of the black power unit.
3) Seperate the 2 halves.
With this many years gone by, often the grease will have dissipated to near nothing. There should be a copious amount of grease on the center spindle, as well as on the toothed plastic attached to the base of the mast. Gob on a generous amount of grease, and give the metal mast a good cleaning then coat it with WD40, manually extending and compressing it as you do so to achieve unhindered operation. Then resecure both halves of the power unit.
Old Jun 8, 2014 | 09:49 PM
K, so sorry bout the long time no reply.. I have to add this to my problem, the antenna won't extend past the first level, it just won't budge... I will try to take it apart now and see about that grease. Will let you know what goes on...
oldjaglover
Dec 25, 2024 04:33 PM
Presence
Mar 13, 2016 02:21 PM
philwarner
Jan 31, 2016 09:36 AM
Kaeghl
Sep 25, 2015 12:49 PM
