Antenna fuse x300 ?
Old Aug 10, 2020 | 08:19 AM
mh.anthony6's Avatar
Default Antenna fuse x300 ?
My antenna is stuck and makes this really annoying noise when trying to open or close is there a fuse or something i can do to keep the radio working but lose power to the antenna?
Old Aug 10, 2020 | 08:43 AM
Parker 2's Avatar
See page 222 and 36
http://www.jagrepair.com/images/AutoRepairPhotos/jagxj1996.pdf
Old Aug 13, 2020 | 01:37 AM
SleekJag12's Avatar
Fuse F8 in the trunk fuse box feeds the aerial. Problem is, it also feeds the remote trunk release and the radio memory. You can remove the power plug from the aerial if you pull back the trunk liner. Beware, your reception may suffer! Not that broadcast has anything to offer (maybe the occasional sports coverage). I'd rather listen to a tape.
The aerial's plastic feed strip is probably broken. Common, and easy to replace if you were so inclined.
Mgebhardt
Jul 24, 2018 08:58 PM
Qvhk
Nov 29, 2017 09:40 PM
RogB
Jul 29, 2017 08:21 AM
Swagguar
Nov 3, 2015 04:29 PM
jehart49
Aug 2, 2014 08:51 PM
