2000 xj8 antenna help
Old Jul 22, 2018 | 09:54 PM
Mgebhardt's Avatar
Default 2000 xj8 antenna help
is it possible to drive with the antenna down? When I turn the car on the antenna automatically goes up even if the radio is off. Any suggestions?
Old Jul 22, 2018 | 11:23 PM
grantorino62's Avatar
Assuming it's wired stock, the antenna will raise with any audio source you choose; tape deck CD or radio. I pulled the antenna fuse in the trunk on my car 3 days ago.
Old Jul 23, 2018 | 12:54 PM
Mgebhardt's Avatar
When I turn the car on even with no cd in use, radio, or tape on, the antenna still rises. wondering if any way to drive with it in the down position?
Old Jul 23, 2018 | 03:04 PM
iwillfixit's Avatar
You need to pull the fuse. There is no other option stockwise to leave the antenna down.
Old Jul 23, 2018 | 07:57 PM
Highhorse's Avatar
Sorry no, you can unplug it in the trunk as I've done and install a hidden antenna (if you want) as I did years ago... https://www.jaguarforums.com/forum/x...ve-one-103359/
Old Jul 24, 2018 | 02:20 PM
Milowokie's Avatar
If you're feeling electrickery minded, you could put a physical switch in the aerial trigger switch loom.
Depending on how your head unit triggers the aerial*, with your HU on and the extra switch off nothing happens, but with the HU on and switch on the aerial goes up, and down when either are switched off.
Worked on the second mast I fitted to my ALFA 75 (Milano) when the first one snagged a plastic bag on the motorway at exactly 70mph and became a little 'distorted', fitted the switch so it only came up when I wanted it too.
Not done it one the Jaag. I really should since most of my radio is received via DAB.*some send an energising pulse on start-up/shutdown, some send continuous 12v to the aerial motor circuitry.
Old Jul 24, 2018 | 04:50 PM
Carnival Kid's Avatar
Am I missing something here? If my radio/CD/tapedeck is not turned on, my antenna stays down, and I drive with the antenna down. If at any time I turn the radio/CD/tapedeck on the antenna automatically raises. And if I turn the radio/CD/tapedeck off, the antenna automatically lowers.
Old Jul 24, 2018 | 08:58 PM
Highhorse's Avatar
Yes, all radios now a days have the power lead function for the antenna (radio, cd or deck use) unless its a windshield or fixed unit. Its usually the blue wire on 3rd party units. Factory units have been doing it since the 80's. Power is delivered to the mast motor when any power function is activated and mast motor power is released when the head unit power is shut off.
Moseleykmc
May 13, 2020 11:50 AM
mhessen6
Jan 23, 2016 09:21 AM
coudamau
Jan 3, 2014 12:04 PM
2Jag
Feb 9, 2011 05:25 PM
rpeppers
Mar 22, 2008 10:08 AM
