I recently bought a '97 vanden plas on the cheap. It runs pretty well. A couple of engine compartment leaks I need to figure out when the cold weather breaks. But one annoying issue is I get the smell of coolant when I get in the car. I get heat and I don't detect any leakage but from what I've read the only real fix is to replace the heater core (unless I wanted to bypass it, but I live in a cold winter area) Has anyone had experience getting to theirs? Does the entire dash come out or can you dissassembe it partially? I'm not looking forward to it but I may have to. Thanks
I guess my question is for a left hand drive car can the heater core be replaced without disturbing the AC. That would make the job much easier I would think. I'm tempted to try and use K-Seal but haven't as of yet. The smell is worse after the car has been sitting, when I drive around I barely notice it. There's also a slight odor in the boot. I was thinking that the leak is very minor but the smell still manages to permeate out.
It's amazing, except it's not clear if the heater core is in the AC box with the evaporator.
It is, it's rearward of the AC evaporator. You don't need to disturb the AC to change the heater core. I don't believe you need to remove the dash to remove the heater core.
I replaced the heater core in my car not long after I bought it as there was very little flow through the core even though I tried various descaling fluids try to clear it out
Bear in mind though that my car is RHD and all I had to remove to access the heater core was the glove box, the rest of the dash stayed put.
In your car you might be able to get away with undoing the upper steering column bolts and laying it down.
I have attached some pix I took when I did the work on my car, it may give you some idea of what is involved
Cheers,
Jeff.
P.S. After I had replaced my core with a new one I filled the old one with kettle descaling fluid and boiled it using a heat gun on the end tank and after several repeated treatments the flow through it as about 90% of the new one with no apparent damage from the fluid. I had nothing to lose trying this as there was a new core already in my car.
P.P.S. Best to get any coolant leak into the cabin of the car fixed ASAP as ethylene glycol, a component of the coolant, when it is hot and vaporised is nasty stuff. Google it and check out the PDS if you want a scare.
The general area with the glovebox removed. The rectangular box with the shiny fitting on it contains the body processor module (BPM)
The heater core with the pipes disconnected. You can see the buildup of scale in the spigots. With the pipes out of the way the core slides straight of the A/C unit.
You can see the hose clamps in the first pic. You can also see in the second pic that the pipes are O ring sealed into the spigots with the little clamps holding it together.
Cheers,
Jeff.
Thanks!! That doesn't look too bad. I'll have to give it a go this summer.
