audio problem
Old Jun 19, 2020 | 09:06 PM
74daimler6's Avatar
Default audio problem
Symptom
after battery discharge, i charged the battery and started engine and also drove.
but the audio is not worked. it does not work power on and other buttons.
is there anti theft function? or any other setup?
some suggested that i put the ejcect(tape) button.
but how? what times? ---- this is not details.
if you have any ideas, please answer to me............
Old Jun 19, 2020 | 09:55 PM
Parker 2's Avatar
There is a security code you can put back into the stereo head
The security code is obtained from some other source other then then Jaguar as they don't maintain the list anymore
Old Jun 20, 2020 | 06:23 AM
countyjag's Avatar
It is worth googling it, as there certainly used to be places where they could tell you the code from your VIN number. Also check in the owners handbook if you have it. The code was originally printed on a small credit card sized card, which might still be there.
Old Jun 20, 2020 | 06:45 AM
John P's Avatar
You can also find advertisers on eBay that charge about 1GBP, you provide them with the serial number and they send you the code.
Just enter Jaguar radio codes.
John
Old Jun 20, 2020 | 11:01 AM
Parker 2's Avatar
If you reversed the battery charger cable clamps it will blow a couple of fuses , this will also happen if you install the battery in backwards
Ask me how I know .
One of the fuses is for the stereo , there are 3 fuses for the stereo
# 8 / 15 amp trunk fuse box
# 10 / 5 amp trunk fuse box
# 1 / 25 amp trunk fuse box ( for the stereo premium option separate power amplifier )
rexus31
Sep 25, 2019 12:27 PM
hen555
Nov 23, 2017 01:56 PM
Frenchy
Aug 6, 2015 03:28 PM
gmcgann
Mar 20, 2015 11:57 PM
SynySTR
Sep 30, 2014 10:00 AM
