Battery connection to check
Old Dec 10, 2017 | 10:05 AM
Scotlad's Avatar
Default Battery connection to check
Stripping down my wrecked 96XJ6 I have come across some things that I thought I would pass on. The little plastic fuse box assembly that connects to the + battery terminal has 2 studs that cables go to. It has a plastic cover over it that just snaps off and then you can access the nuts. Both of mine were slightly loose on this car and also I discovered, on my daily driver. I always keep my battery clamps clean and tight but I had never thought about checking these connections before (out of sight out of mind).
The only reason I caught this is that I was removing this piece for spare parts. I had never thought to look under this cover but a loose connection there could create starting or charging problems.
Maybe someone could post a picture of the part.
Old Dec 10, 2017 | 10:33 AM
Lady Penelope's Avatar
LNA2850DE superseded by LNA2850DE
https://www.jaguarclassicparts.com/a...ibution-cables
beady
Apr 18, 2024 02:42 AM
redd
Jul 2, 2014 12:28 PM
Roger77
Feb 15, 2013 05:13 AM
ixj8it
May 23, 2011 06:41 AM
johnfromseattle
Jan 15, 2011 02:33 PM
