Battery problem
Old Oct 9, 2017 | 11:28 AM
jomo's Avatar
Default Battery problem
After my cars sits for 3 days I have a dead battery condition. Walmart claims the battery is good.
Here is what I found. After charging the battery it has 12.51 volts. When running at idle the battery reads over 14 volts. The drain is 0.02 Amps which I suspect is fine.
I'm concluding that the battery is in fact bad. There is just one way that I can think of where the battery is good....
Is it possible that while the car is sitting that the drain jumps from .02A to a higher draw?
Thanks,
Jomo
Old Oct 9, 2017 | 11:54 AM
Lady Penelope's Avatar
Most auto part stores will test the battery for free but you have to leave the battery with them for a hour on their test stand .
Full battery charge is 12.77 volts
If you can't charge to 100 % then that is an indication alone you have a bad battery not taking a charge
Old Oct 9, 2017 | 02:09 PM
Alster370's Avatar
Good test is to remove the battery from the car when charged, let it sit for 72 hours alone and look at the voltage drop. If your getting 12.7 down to 12.4v in three days or something then clearly a bad battery. I have a second car that sat for 4 weeks with a new battery, started first time on the key.
Old Oct 10, 2017 | 08:51 AM
jomo's Avatar
I tried this overnight and did see a drop in voltage. I just came back from Walmart with a new battery. They really did not want to replace it but I insisted. The new battery has a higher voltage- .5V higher! I think the problem is fixed.
Thanks!
Old Jun 8, 2020 | 06:31 PM
supersportmtl's Avatar
hmm
Jagstefano
Dec 26, 2018 04:25 AM
muskox3437
19
Oct 13, 2016 09:52 AM
Cadillac
General Tech Help
Sep 23, 2014 12:39 PM
Rique
May 8, 2012 09:05 PM
mojorising
Oct 26, 2010 09:52 AM
