Boot/trunk strut replacement
Old Jan 20, 2013 | 08:46 PM
dmpsqrd's Avatar
Default Boot/trunk strut replacement
Checked the stickies- no dice. anyone have a link to a how - to relacing the trunk/boot struts on a '96 xj 6? thanks in advance- d
Old Jan 20, 2013 | 09:22 PM
aholbro1's Avatar
Try "Search" it's in here somewhere....I recall it from several months ago..
Old Jan 20, 2013 | 09:46 PM
Roger95's Avatar
The're quite easy and just "pop" off. On the driver's side (left) work a long pry bar between the end on the strut and something to back up the pry bar and give the pry a sharp twist/snap and the strut will pop off. On the right hand side you have to move the electric harnes that's in the way and do the same. The new struts will easily snap into position. Shouldn't take you more than 10-15 minutes tops.
Old Jan 21, 2013 | 07:30 AM
V126man's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
Default Boot/trunk strut replacement thread
I think this is the thread that you need
https://www.jaguarforums.com/forum/x...ht=trunk+strut
Forcedair1
Sep 8, 2025 01:57 PM
RoyLittle0
May 25, 2023 02:38 AM
cissdm
May 3, 2016 06:02 AM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
