Brake problems
Old Aug 5, 2020 | 12:10 PM
jomo's Avatar
Default Brake problems
Hi,
Yesterday I took out the old Jag (1995 XJS-6cyl) for a drive. At some point I wanted to make a right turn but when I hit the brakes to slow down there were no brakes.
Later on there were some brakes and then no brakes and then good brakes for the rest of the trip. I made it home safely!
The main hint I can give you is that when there were some brakes the whole front end violently shook only when I hit the brakes. When the brakes were good there was no vibration. While driving no shaking at all.
Another point I should mention is that when I got the car a few years back the brake pedal has always been hard.
Any hints as to what I should be looking at?
Thanks,
Jomo
Old Aug 5, 2020 | 04:37 PM
Parker 2's Avatar
From reading others there seems to be a common complaint of hard brake pedal on a properly functioning system , at least on the 4 door sedan
Even though it is a XJS , the inline 6 engine brake boost vacuum line fitting at the intake manifold is a Squirrelly banjo fitting on the top of the X
The question on the production number of the 1995 XJS is the engine and it's parts for a AJ6 or AJ16
The large brake boost diaphragm can also be leaking
Air in the brake lines ? U shaped bleeder hose ?
Further compressible air in the brake lines allow the caliper piston pads to not be held steadily against the rotor so it sets up a situation of oscillations
Old Aug 7, 2020 | 07:46 PM
jomo's Avatar
OK, I am extremely confused. I can't find my brake booster. I looked between the firewall and the master cylinder but do not see what I thought a brake booster would look like. I also looked for a hose from the master cylinder area to the manifold but did not see any. Can I please bother someone for a picture or a diagram of the hose/brake booster.
Thanks,
Jomo
Old Aug 7, 2020 | 08:38 PM
xalty's Avatar
Thanks,
Jomo
It’s a big fat gigantic round black drum.
Maybe it still has the teves electric booster?
Old Aug 7, 2020 | 08:54 PM
jomo's Avatar
No big round black drum. That was just what I was looking for.
Old Aug 8, 2020 | 07:34 AM
b1mcp's Avatar
It's confusing because you have posted a question about your XJS in the X300 forum.
I'm not very knowledgeable on the XJS but I know many of them had a pump and accumulator set-up - so no vacuum booster. Best to take your question to the XJS forum.
Old Aug 8, 2020 | 09:05 AM
xalty's Avatar
if this is a LHD car look for a black sphere with a big danger sign on the right side of the car close to the firewall. this is the original teves electro-hydraulic pump booster master cylinder combo
this is what an AJ16 XJS should look like, big black drum in the top left corner
lolshto
Oct 18, 2020 02:57 PM
gdelectron
Oct 3, 2020 12:41 AM
Luis Antezana
Jun 17, 2020 06:20 PM
Gadabout
May 16, 2020 03:07 PM
watson6505
Nov 28, 2019 12:03 PM
