Bump causing all dash warning light on for a second
Old Jan 12, 2011 | 05:28 PM
EZDriver's Avatar
Default Bump causing all dash warning light on for a second
The other evening I was driving through a parking gate that had one of those tire devices that block you from going the wrong way. I hate those since it is a pretty significant bump. So I hit it with only the right tires. This rocked the car to the left and all of the dash warning lights came on for just a second. They went off like they normally would when starting the engine. Later on I had to go through the same gate and it did the same thing. I have had a relay somewhere in that area that clunks now and then for no reason (see thread on relay clunking). These two things may be related. Other than these items the car runs fine. I will go under the dash as soon as it gets warm and see if I can find a loose connector.
I would like to hear from anyone that has had a simular problem.
Thanks guys.
EZDriver 95XJ6 2000XK8
99xk8guy
Sep 29, 2025 10:51 PM
JarodL
Mar 7, 2024 01:39 AM
D.K
Dec 10, 2023 02:05 AM
Jpav27
Jul 31, 2022 06:43 AM
OkieTim
Sep 2, 2015 12:48 PM
