Bushing Help?
Old Dec 13, 2016 | 12:07 PM
Canuck XJR6's Avatar
Default Bushing Help?
Hi Guys,
I need a couple of rear bushings on the XJR but not sure what Jaguar is calling them.
They are located on the knuckle/spindle (as we call them in Canada) and can't seem to find them on the parts websites. Pic shows where the bushing is.
Thanks,
Chris
Old Dec 13, 2016 | 12:35 PM
b1mcp's Avatar
It's a bearing rather than a bush. See this page
Hub Carrier and Hub Assembly-Rear - Parts For XJ Series from (V)720125 to (V)812255 (X300) | Jaguar Classic Parts UK
Suggest you dismantle to check what you need before buying as sometimes the pivot bolt and/or the spacer tube are corroded and seized to each other and/or the bearing.
Old Dec 14, 2016 | 02:20 PM
Thanks for the intel B1mcp!
I'll have a look before I order the part(s).
Old Dec 15, 2016 | 04:51 AM
aholbro1's Avatar
Make sure you get a new hub-nut; they are one-use only
Old Dec 16, 2016 | 08:34 AM
Thanks aholbro1!
