Call me stupid
Old Apr 18, 2008 | 01:43 PM
RickSku's Avatar
Default Call me stupid
I can't find the spark plugs in my 95 xj6. I did get the starter changed with some great advice in my other post. So anyway it turns over and I got a slight fire like it wanted to start then nothing. I get a little bit of a gas smell but it won't start. The car has sat for 8 months so I put some heet and some stabil in the tank along with a gallon of gas. I took the chrome cover off the side of the engine and there is the exhaust manifolds but I don't see any spark plugs same thing when I look under the fuel injection rail.Maybe i been with Chevies to much and I feel like a fish out of the water. I am also to cheap to buy a service manual so here I am asking you guys where the freakin plugs are. I really need to get this car started so I don't have to hear from my wife the ( I told you so). This is my first jag and even though I am having problems I am still having fun. Thanks Rick
Old Apr 18, 2008 | 03:57 PM
bigdreams05's Avatar
Default RE: Call me stupid
Check under the coils.
Old Apr 18, 2008 | 07:41 PM
FactoryJaguarTech's Avatar
Likely not the plugs. But I don't work on the old stuff.
Old Apr 19, 2008 | 08:59 AM
jag_genius's Avatar
may be flooded.. rare but happens.. change the oil .. and three torqs on top of the engine to get cover off.. then there are 6 coils.. remove all 12.. 8 mm bolts.. then remove coils then plugs..
Old Apr 19, 2008 | 12:21 PM
RickSku's Avatar
Thanks for the info. I found them and I will replacethem. When I checked the spark it seemed to weak and the gap was only 25 thousanths. They haven't been replaced in a while. Thanks again Rick
Old Apr 19, 2008 | 12:54 PM
jag_genius's Avatar
before you put spark plugs in.. drop couple drops of oil in the spark plug hole in the engine.. then install plugs.. and make sure battery is charged well.
kthrash
Feb 25, 2019 10:20 AM
jagxk2008
Feb 4, 2016 09:53 AM
BlakeConverse
Sep 28, 2015 02:22 PM
d33
Sep 26, 2015 11:02 AM
redgear
Sep 26, 2015 07:21 AM
